-   -   Broken Timing Chain, what else should I look for? (http://forums.pelicanparts.com/porsche-911-technical-forum/534861-broken-timing-chain-what-else-should-i-look.html)
daddygo 04-03-2010 06:37 PM
The timing chain broke on a 2.4 CIS on a 1973 911T. What else should I look for?
Do the valves have negative clearance with the pistons? Wondering if I have a row of bent valves.
James Brown 04-03-2010 07:28 PM
They should clear as long as you didn't over rev it. Chain ramps, chain sprockets, check for wear, make sure all the chain pieces are accounted for. Hope for the best!!
yelcab1 04-03-2010 07:31 PM
in this case, a compression test is your friend.
