help exhaust upgrade
i'm going to do an exhaust up grade to headers and a sport muffler. Any ideas or comments on how to get the heat exchangers off.The bolts an allens look very rusty . all comments wanted
thanks Tony
73 914 2.0 gone but never forgotten 83 911 3.6 DE only |
The general drill is PB Blaster, heat, more of both and if that fails, cut off the nuts using whatever drill/grinder you can get in there. I think on my 88 I only had to cut off a couple. It it imperative you use caution not to twist off a stud as they are undoubtedly weakened by heat cycling and rust. Yet quite q task to replace. Good luck. Search for stories. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
I did this last weekend. In my case, I applied PB blaster every evening for five days in a row. Then I used one of the cheap-o MAPP/Oxygen torch kits that are commonly available. I heated each nut until it was just starting to show a very dull red when I would pull the flame away. I was then able to wrench each nut cleanly off.
However, my car spent its life in kind climates and there was not that much corrosion to begin with - so I felt my odds with heat were good. The other option which seems to work very well is to dremel a slot most of the way through the nut and then use a cold chisel to seperate and turn the nut. I have not done this myself, but everyone that had every wrote about it has had good success it seems. |
thanks guys
whats with the sport muffler? i thought shorties were in order?
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
Liquid wrench, heat, hammer and punch, 4" cut off wheel, dremel, chisel, lots of patience .....good luck
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
