Question Starting Pressure for RT 615's
I recently purchased a set of Falken RT 615's that I will be running as rain tires at DE's this year. I emailed Falken but received no response regarding heat cycling or starting pressures so I thought I would see if someone might be able to help.
I have been running Hoosier r6's with (225/45/17's F and 245/45/17's R) on an 84 911 that is track prepped and weighs about 2300 pounds with me in it.
My starting pressures have be 26 front and 32 rears.
Any suggestions for the Falkens would be appreciated.
Can you run these green or do you need to heat cycle them like the r6's?
Thanks in advance.
Old 04-05-2010, 01:00 PM
