-   -   Finally COntinuing Engine Evaluation - Piston help (http://forums.pelicanparts.com/porsche-911-technical-forum/535265-finally-continuing-engine-evaluation-piston-help.html)
docrodg 04-06-2010 05:50 AM
Hi All,
Been traveling and remodeling a bathroom so no time (and too cold in unheated garage) to continue my teardown of the motorsheister autopsy I started last fall. Finally got time to get back to it and found one of my micrometers out of calibration. Got that fixed so I can go on and measure everything and will post update in next couple of days (things are going slowly, I cut the end of my thumb off).
In investigating the pistons and cylinders further I have a question on these regarding the manufacturer marks to assist in determining if they were swapped out by those hacks.
Pistons have ID number 80P26E - searched many places and I know it was a number for 69 but I have a 68 S - was this also a 68 S number?
Cylinders are biral (80zd3) but is there a difference in manufacture that would id if they are indeed for a 68 motor?
Help is much appreciated.
docrodg 04-08-2010 06:13 AM
Anyone??? From what I have found around the only reference to these numbers are for 69 S pistons. Is that correct?
304065 04-08-2010 07:34 AM
Sorry to hear about the end of your finger!
Here is the most complete list by our friend Tom.
Piston I.D.? - Early 911S Registry Bulletin Board
That suggests that they are 69S. Do you have a photo, it's easy to confirm.
docrodg 04-08-2010 07:40 AM
Thanks! "It's just flesh wound." haha!
I will get pics up later... I am finally continuing my autopsy of this motormeister rebuild and finding more scary stuff, but it is taking a long time to clean these parts up and measure as I have other obligations, and my thumb slows it down. Seems that chem-dip is a strong cleaner - and on a major flesh wound like mine it can cause new and "elevating" levels of pain. SO I am basically stuck doing all cleaning one-handed right now.
