Mixing Synthetics
Can you mix synthetic oils? I know some normal oils react poorly to each other (foaming), or so I have heard. Does this happen with synthetic?
Yeah , no problem...you can never get all oil out of the engine enyway. Just don't mix synthetic with minerals.
Thank you for your time, |
on the contrary, you can mix synthetics with minerals. it is called a blend and is perfectly fine.
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
