Oil pressure gauge needle bouncing
Hi everyone:
I have a 1985 911 Carrera and the oil pressure needle started to bounce erratically. Sometimes it stuck past the number 5 in the scale and when decelerating it went down. I changed the oil pressure sender for a new one and it cleared the problem for a while, then started again. Now when I accelerate and the needle reaches the number 4 in the scale it bounces up and down. If I maintain the pressure about 4 it remains normal, no bounce. What can be happening?
Any help would be appreciated and thanks for your attention.
Old 12-03-2001, 05:53 PM
Senior Member
Superman's Avatar
These German pressure gauges and sending units have a reputation for jerky movement. "They" say that for truly precise and reliable oil pressure readings you need to use a mechanical gauge. It may help to just make sure your electrical connections are excellent.
Mocha 1978 911SC. "Coco"
Old 12-03-2001, 10:04 PM
It sounds like your sender is still working OK, but as Superman said I would check the connections and wires associated with the gauge.
Old 12-03-2001, 11:54 PM
Olivier 3.0's Avatar
Send a message via ICQ to Olivier 3.0
Arrow
I had the problem with both pressure and temp gauge, with a "sticky" needle and erratic movements... I fixed it by blowing the mecanism with a computer air bomb (carefully!), and dropping a tear of 3in1 oil on the axis of the needle. To do that, I previously put the tear on a sewing (I suppose it's the right word) needle, and then put this needle on the axis; by capillarity, the oil "jump" to the axis...
I do not know if it will solve your problem, but it did solve mine
Olivier.
'76 Carrera 3.0
Old 12-04-2001, 01:00 AM
