Jumping tach and photo of my car!
Hello All,
Where is the pick up for the Tach on a 930/911?
I heard it is in the dist. ? Are there visable contacts I can clean or is this electronic? My Tach is jumping whenever it gets in the mood. So I was thinking it would be the pick up. OR If someone else has and idea please feel free...
Richard
86 930
Old 12-04-2001, 12:48 PM
jkcrewsn's Avatar
Nice 930! My tach was jumping around a lot too. I was told I would have to send to a gauge shop to get rebuilt. I ended up installing a tach adapter when I put an MSD ignition system in. That cleared it right up and it works perfect now. I am not all knowing by any means, but the wiring harness on the CD box has a tach wire, and the magnetic pickup comes off the distributor going to the same clip. I can't tell you why mine wasn't working before, or if yours is even the same as mine (years older). But mine was not a gauge problem. So be sure you check the connections before you spend the money getting it rebuilt, as that may not even help. Wish I could be a more specific help.
Jeff
'79 930
http://www.pelicanparts.com/gallery/jkcrewsn
Old 12-04-2001, 01:03 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I don't have a 930, but when my tach started jumping around, I was told by this board to check my points and clean it. If your 930 still uses points that would be the first thing to try and clean. Good luck.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 12-04-2001, 01:26 PM
Bill Douglas's Avatar
Nice wheels Richard. Are they polished or chromed? Bill '79SC
Old 12-04-2001, 01:28 PM
Send a message via ICQ to old_skul
If those are polished, I need to work on my wheels...
I think they're chromed. You'd need to work for days on your wheels to get 'em that shiny.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 12-04-2001, 01:35 PM
