Engine Install / Transmission question
I am re-installing a 3.0 engine into a 911SC w/ 915 transmission. The transmission is still in the car. Using our hosts jack plate, lining up the engine to the transmission was easy, and from the top of the engine as I pushed the engine in I was able to watch that the throwout fork hooked up to the plate ( though I have not verify by looking through the starter hole, so I guess it could have come off ). Before I go start hooking everything back up and put oil in, I want to make sure that the transmission hooked up correctly to the engine so I did the following with the car still on jack stands.
- With transmission in neutral, I spun a rear wheel, and the other wheel did not move. - With the transmission in gear, I spun a rear wheel, and the other wheel spun in the opposite direction. - With the transmission in gear, but the clutch pedal depressed, I spun a rear wheel and the other wheel did not move. I am concerned on how easily the wheels turned with the transmission in gear. I would think that they would not want to move, as I leave it in gear when I park so it doesn't role away if the parking brake decides to fail. This just does not seem right, is this to be expected? Thanks. Last edited by snafua; 04-10-2010 at 08:27 PM.. Reason: fix confusing statement |
How did the clutch action feel?
If it was smooth it probably is connected. If not, I would make a visual check before going forward. I have only connected the combo while out of the car but I believe they won't even mate up correctly when not right.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Action feels the same as when I took it out.
While the engine was out I did not mess with the clutch, I was dealing with oil leaks and cracked vacuum hoses on the CIS, so I shouldn't have messed up anything in that area. If the transmission / engine won't mate if the throwout is not right that is good to know. Thanks |
The Answer from another forum where I asked the same question. I confirmed that when I try to move both wheels the same direction, I can't move them.
This is the expected operation of an open differential as far as I can tell. If you don't have a limited slip diff, then it shouldn't be too difficult to have the opposite wheel turn when the transmission is in gear. When the transmission is in neutral, you're probably just turning the input shaft instead of the opposite wheel. All of this assumes you have an open differential.. Did you try turning both rear wheels at the same time (in the same direction)? *That* should be difficult because now you're turning the engine crankshaft. |
Senior Advisor
All is well
08 Cayenne Turbo |
Somatic Negative Optimist
Visual inspection is the ultimate confirmation.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
and this is another reason why you remove and install them both as a unit.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
