fxeditor's Avatar
Brake system warning light after bleedeng clutch.
Hey all,
So I finally got the 911 back on the road! The last thing I had to do was to bleed the clutch due to the new slave cylinder I installed. However now my brake system warning light is lit! I tried jiggling the two wires that are attached to the reservoir but it didn't help. I've tested the brakes themselves and they seem fine and the clutch shifts great now. Where should I look next?
Thanks in advance,
Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 04-09-2010, 04:44 PM
steely's Avatar
just a couple of thoughts...
Can you remove the reservoir cap and test it with a meter?
Fluid level ok? good wire connection on the spade lugs?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-09-2010, 04:59 PM
Bill Verburg's Avatar
Originally Posted by fxeditor View Post
Hey all,
Thanks in advance,
Michael
Try disconnecting the battery
does it have pad sensors? If so could one have been disconnected
Bill Verburg
Old 04-09-2010, 05:17 PM
fxeditor's Avatar
Thanks for all the advice! The car does have 4 new pad sensors, I put them in about 6 months ago when I changed the pads. The fluid level is at max and I think I'll try testing the cap on a meter. What should I be looking for as far as readings at the cap? If that is the problem ( I'm leaning that it might be) can you get a replacement cap by itself or do I have to blow a bigger wad and get a new reservoir?
Thanks again,
Michael
-- '92 Miata
Old 04-09-2010, 05:33 PM
key on, disconnect battery, count to ten, reconnect battery, key off, start car.
206 637 4071
Old 04-09-2010, 06:36 PM
steely's Avatar
Is that to force a reset John and Bill?
Dan
Venetian Blue
Old 04-09-2010, 09:39 PM
Senior Advisor
James Brown's Avatar
Yes
08 Cayenne Turbo
Old 04-11-2010, 01:13 AM
winter
Winter's Avatar
Would this fix my "flashing" brake light? The flashing started after I rebuilt my calipers. OK, dumb question, I'll just go try it. . .
Next question - is there a "reset" switch on my master cylinder and if so, how do I locate it. Forum was split 50/50 on the subject when I last asked this question. Car is a '75 S targa.
Thanks, John, your contributions to the forum are truly appreciated.
Tom '75 targa
Old 04-11-2010, 06:31 AM
Senior Advisor
no reset on a 75
08 Cayenne Turbo
Old 04-11-2010, 08:05 AM
master cylinder switch on a '75. pull the wire off and see if the flashing stops.
206 637 4071
Old 04-11-2010, 08:49 AM
fxeditor's Avatar
Thanks John, I tried it but it didn't work. I didn't have much time this weekend to trouble shoot it any more than doing the battery disconnect so I'll have try the multi-meter another time.
Michael
-- '92 Miata
Old 04-11-2010, 05:11 PM
