-   -   With Headlights on, Turn signals do not work! WTF? (http://forums.pelicanparts.com/porsche-911-technical-forum/536209-headlights-turn-signals-do-not-work-wtf.html)
mgatepi 04-11-2010 10:46 AM
So I replaced my turn signal lever assy and installed a headlight relay system. All parts from Pelican, and now my turn signals do not work when I have the headlights on!!! I have looked at the wiring diagram here but not sure I am smart enough to understand this.
Any suggestions?? Oh, this is on an 83 SC
Thanks!!
mg
WERK I 04-11-2010 10:57 AM
mg,
Does the turn signal light or indicator come on and not "blink" or do they not light up at all?
First place I would look would be all the grounds up front where they ground to chassis and at the rear grounding of housings to chassis. Start from the front first.
mgatepi 04-11-2010 12:03 PM
With the headlights off, they work perfectly. With the lights on high or low beam, nothing! No blinking no indicators on, nothing!
Thanks all!
mg
James Brown 04-11-2010 12:24 PM
check where you installed the headlight relay, might be touching another fuze. Better yet, try disconnecting the headlight relay and see if that fixes the problem.
