Chain fence eating turbo
Not recommended to run Swepco in G50's, only 915 boxes.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
My 901 shifts better cold when the oil is thickest. Car wants to move before gear engagement is usually a clutch needing to be adjusted. Of course I'm talking 901/915. The G50, I'm not sure what it's characteristics are in comparison. I run Kendall aircraft gear oil.
Bob |
gearhead
For G-50's, try starting the car with the clutch depressed. Do not release until you have it in gear.
If it doesn't want to go into 1st or 2nd, try 3rd for an instant then go down to 2nd then to 1st. Do NOT force it. |
I have read that before. What does that mean if it will still not shift smoothly. My dilemma is if I start my car with the clutch disengaged and in gear my car moves for a split second. Also, If I do not double clutch when down shifting my car has difficulty. There's a delay in disengagement when depressing the pedal and I've been told my input shaft needs to be lubricated and is sticky.
Bob Last edited by Bob Harriman; 11-16-2014 at 03:57 PM.. |
