JED
ARCSinAK's Avatar
SSI upgard Question
Fellow Pelicans-
I have a question in regard to heat exchanger removal. I am aware of the caution needed when removing the bolts due rust/coresion and have been instructed to use a torch and get the bolts red hot. on my 911 there is one bolt and one allen screw. Was this the normal factory set up? Your thoughts and advice are welcome. thanks for your time.
Regards-
JS
Old 04-11-2010, 06:40 PM
Free minder
Aurel's Avatar
Yes, that is normal. The allen bolt is to use an allen key through the hole in the heat exchangers, since a socket wrench would be too thick to go through the hole.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 04-11-2010, 06:47 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Hello,
The allen is a nut, I got a long 8MM on eBay for about $8.00 in 3/8 drive. The rest is history, be careful with the nuts, and it will all go like buttah.
I think the SSIs are the single best engine mod to date, be prepared for a new car, and better power!
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-11-2010, 07:36 PM
grateful user
don gilbert's Avatar
Ive done this swap a few times now, don't know why, but i have better luck using no heat. Twice ive started nut removal with heat and snap..Now I soak them in Kroil, take a punch and give them all wacks with a hammer for a few days. Hav'nt broken one since, and ive done some rusty onesl Get the best 8mm 3/8 drive allen socket you can find, (DO NOT USE Harbor Fright allens) I have a short 13mm box wrech bent into an S for the hard one, 1/4 inch drive ratchet with 13mm socket and swivel for the rest.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-11-2010, 08:49 PM
