Transmission Leak between Front Cover/Gear Housing (915)
Car developed a transmission leak at the track this weekend. Looked like hte paper gasket tore/ripped and a small piece was pushed out (??) letting my previous fluid leak out. I patched it with some silicon to help slow the leak down for now but it's still there.
It appears the part number is 915-301-351-00. Is this something a DIY'er can do or does it require dropping the engine/transmission? Thanks for any and all help! |
Tranny does have to come out to repair but this would be an easy fix once it's out. Engine removal can be a DIY project.
-Andy
72 Carrera RS replica, Spec 911 racer |
those newspaper thin gaskets can be squeezed out if too much sealer is applied. when the nuts are tightened, the sealer squeezes out and takes the gasket with it. i like K&W coppercoat spray. let it tack up before squeezing.
gearhead
We don't even use the paper gaskets anymore and just use Loctite 574. The 915 isn't like the 901/911 where the paper gasket is actually a pinion shim. On the 915 you can remove them and replace with a modern sealant.
However, as was mentioned, it will have to come out to fix it.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
