-   -   rs vs rsr fender question (http://forums.pelicanparts.com/porsche-911-technical-forum/536354-rs-vs-rsr-fender-question.html)
toddc 04-12-2010 08:22 AM
I'm a little confused.
I keep seeing pics of rs's and rsr's and I curious about which fender is which.
What I'm looking for is the fender that looks vented at the door opening. Looks as though it's a couple inches wider than the front edge of the door.
Anyone know what I'm referring to?
Thanks,
--toddc
trak ratt 04-12-2010 08:29 AM
Which years and which cars? RSR are usually wide bodied front and rear, RS not so much.
JeremyD 04-12-2010 08:30 AM
http://www.rennspd.com/PImages/FF-91...0710173053.jpg
Both really are RSR - there's an 11" flare (rear) and a 15" vented flare. (they actually make a 13" too)
Both are referred to as RSR flares.
The 11" flare (rear) is mated to a 9" front flare - these are similar to the regular Turbo Flares
The 15" vented flare needs to be mated to the 11" front RSR flare that is also vented in the rear.
The "RS" flares are more in line with the regular SC/Carrera profile but on a longhood car.
toddc 04-12-2010 09:02 AM
Yep, Jeremy's got it.
That's the one I was referring to. So, it's 11" front and 15" rear?
I also saw long hood mentioned. I assume this is what a 74 would have been?
--todd
stormmaster 04-12-2010 09:07 AM
Actually 74 and later are short hood cars....
JeremyD 04-12-2010 09:18 AM
The 15" are a little cartoonish - as in the rear wheel sits WAY outside The 13" is not quite as extreme. - Just my opinion.
boba 04-12-2010 10:37 AM
Jeremy is correct.
The '73 RS has stock front fenders and the rear is similar to the later SC and 3.2 Carrera. It is sometimes referred to as a 8" or 9".
The '73 2.8 RSR (long hood) had the 9" front and 11" rear that were blended into the rest of the body.
The '74 3.0 RSR (short hood) had the 11" front and 15" rear.
The 3.0 RS (short hood) had the wide body of the early turbo.
toddc 04-12-2010 12:14 PM
Got it.
the longer hood curves down at front edge doesn't it.
Todd
toddc 04-12-2010 12:16 PM
Originally Posted by boba (Post 5291008)
Jeremy is correct.
So was there ever a 13 or 15 rear blended with the 11 front or any other front fender that had the vent in the rear edge where it meets the door?
--todd
boba 04-12-2010 12:37 PM
--todd
There were many team configured flairs thru the years as the rules allowed larger wheels and track width. The ST years had some of the most unique team constructed flairs. So, it is very possible that someone ran something like that, even the factory had some wild configurations with the early prototype RSR's. It seems that at almost every race meeting they had different setups in early '73.
TRE Cup 04-12-2010 04:30 PM
http://forums.pelicanparts.com/uploa...1271114952.jpg
http://forums.pelicanparts.com/uploa...1271114966.jpg
73 "RS" look= 8" flares. (this is actually an SC, but good enough for discussion sake)
TRE Cup 04-12-2010 04:31 PM
http://forums.pelicanparts.com/uploa...1271115048.jpg
http://forums.pelicanparts.com/uploa...1271115063.jpg
73 RSR look- these are actually 911 turbo flares, but basically the same as the 73 RSR
TRE Cup 04-12-2010 04:34 PM
http://forums.pelicanparts.com/uploa...1271115174.jpg
http://forums.pelicanparts.com/uploa...1271115233.jpg
74 iroc RSR used turbo width fenders , so essentially the same flares as the 73 RSR
TRE Cup 04-12-2010 04:35 PM
http://forums.pelicanparts.com/uploa...1271115338.jpg
http://forums.pelicanparts.com/uploa...1271115349.jpg
74-75 RSR - the big one !
toddc 04-13-2010 07:43 AM
Thansk,
Looks like a set of 74-75 rsr bodywork will be in the works :)
--todd
Tom '74 911 08-25-2010 06:37 PM
Todd -
Just curious if you've sourced '74-'75 RSR bodywork. I've started to think about doing this to my car, but haven't been able to find any good references for the fenders and bumpers etc...
Tom
joeblow 08-25-2010 08:30 PM
Try AIR, GT-Racing, Getty Designs, etc....I am sure there are more....
Originally Posted by Tom '74 911 (Post 5526397)
Todd -
Tom
