-   -   What's This In My Tool Kit? (http://forums.pelicanparts.com/porsche-911-technical-forum/537001-whats-my-tool-kit.html)
big911fan 04-15-2010 04:18 PM
Can anyone identify the two tools pictured in my tool kit just below the long Phillips screwdriver bit? The item on the left is a hollow tube about 3 3/4" x 3/8" long and the item on the right is a rubber coated wire with two prong tips.
I was wondering if the tube is a handle for the speed wrench (although it's a sloppy fit) and if the wire is maybe a fuse puller since it's rubber insulated. Just a wild guess, though.
Also, I assume I should have a handle for the Phillips screwdriver bit but it's missing. Thanks.http://forums.pelicanparts.com/uploa...1271373443.jpg
1986911 04-15-2010 04:27 PM
The metal wire is to remove the center caps on your wheels. It goes in the two holes, then you pull.
http://forums.pelicanparts.com/uploa...1271373996.jpg
Don't know about the other one.
aj88cab 04-15-2010 05:14 PM
I believe the tube is a handle for the long allen wrench that is used to remove the bolt on the battery hold-down bracket. At least that is what I use it for...
