Northern, CA
What's This In My Tool Kit?
Can anyone identify the two tools pictured in my tool kit just below the long Phillips screwdriver bit? The item on the left is a hollow tube about 3 3/4" x 3/8" long and the item on the right is a rubber coated wire with two prong tips.
I was wondering if the tube is a handle for the speed wrench (although it's a sloppy fit) and if the wire is maybe a fuse puller since it's rubber insulated. Just a wild guess, though.
Also, I assume I should have a handle for the Phillips screwdriver bit but it's missing. Thanks.
Old 04-15-2010, 04:18 PM
1986911's Avatar
The metal wire is to remove the center caps on your wheels. It goes in the two holes, then you pull.
Don't know about the other one.
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 04-15-2010, 04:27 PM
aj88cab's Avatar
I believe the tube is a handle for the long allen wrench that is used to remove the bolt on the battery hold-down bracket. At least that is what I use it for...
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 04-15-2010, 05:14 PM
