fog/defrost knob question
has anyone ever dissected one of the fog or defrost switches from an sc? i want to remove the rubber surround but they have me a bit puzzled. for example when i stand them up so the knob is on top and then put pressure on the rubber to force it down off the lighted face the whole metal pole moves inside. i am afraid to do it now in case i would somehow mess up the connection. i really don't want to cut it if i don't have to.
http://i15.photobucket.com/albums/a3...ts/button1.jpg http://i15.photobucket.com/albums/a3...ts/button2.jpg |
Try GENTLY prying just the plastic "face" off. Use a jeweler's flat blade driver. I believe they are just pressed into a groove in the rubber.
BTW---What is the goal here? |
Maybe to make buttons out of 'em?
Michael |
I've never opened that one up, but on the headlight switch you have to pry the plastic face plate out first. Then the switch inside was held to the rubber with a nut that had to be removed. If you remove the plate it should be more clear how to take it apart. There is a bulb in there so be careful.
I have
In order to remove the metal post, you have to cut them. It is possible to get the symbol out with a small screwdriver, but to get the rubber off, it's only the knife.
Ken |
| All times are GMT -8. The time now is 11:16 PM. |
