Oil Leaks
On a 86 3.2 I thought the oil cooler was leaking and changed the seals..no luck..seems to be coming from top of case? valve cover gaskets are solid and new? Any thoughts thanks rjm
Old 01-03-2002, 11:19 AM
Senior Member
Leland Pate's Avatar
I'm betting on one or more of the following things.
One- oil thermostat o-ring leaking
Two- oil pressure switch leaking
Three- Crankcase breather hose or housing gasket leaking.
Do a search, there is plenty of discussion on this topic. Very common.
Chief Architect and Mastermind,
SCWDP
Old 01-03-2002, 11:23 AM
