-   -   Tachometer always start to fail after 5min driving (http://forums.pelicanparts.com/porsche-911-technical-forum/537235-tachometer-always-start-fail-after-5min-driving.html)
lizola 04-17-2010 03:47 AM
Hi Can anyone help? Thanks.
I'm a newbie here.
The Tachometer of my 3.2 always works fine on starting and consistently dies on me after 5-10mins driving.
This makes me think its a mechanical problem that is exacerbated after warming up
Is the "tachogenerator" a mechanical part? --> Its the source of the signal to the DME right? If so, where is it located. Thanks
Davewjunior 04-17-2010 03:56 AM
I've had the same problem for awhile now so I'll be watching this thread. Mine will stop after a few minutes of driving. Sometimes tapping on the gauge will help or driving over a bump will make it work/stop working. New ignition coil (happened with the old one too).
GeorgeK 04-17-2010 04:07 AM
I'd say a corroded earth that gets worse as the wiring heats up.
vesnyder 04-17-2010 04:17 AM
My tach went crazy when my alternator went bad. I was on a long trip and when I got close to home it freeaked out! I suspect it is something electrical. Start with checking teh charging system - alternatory and voltage regulator. Good luck!
