-   -   poor running 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/537390-poor-running-911-a.html)
la975 04-17-2010 09:56 PM
poor running 911
84 911 runs poor after dead battery jumped and then replaced. Starts and idles fine. Won't rev, give it gas and it stumbles very badly and backfires. Can't drive it at all as it has no power. Pumping gas and it will rev some but still very rough, backfires, and then stumbles to idle.
DMC resistances check out. pump relay replaced along with fuse. New cap (had a crack), rotor, coil, and spark plug wires replaced and it runs a little better, not much though. Platinum plugs cleaned and re-gaped. Reference sensor and speed sensor resistance check out and car won't start with either of them unplugged. Oxygen sensor replaced since it's near 60,000 miles. Also, fuel pump spinning fine and running pressure is good.
Could this still be the speed sensor? Any thoughts would be appreciated.
TibetanT 04-17-2010 10:07 PM
Make sure that your firing order is correct. Could be the spark plug wires were put back in the wrong order. (Which would be the back fire problem.)
Did you by chance put the reference sensor/speed sensor in the wrong order as well when checked? Just a guess on my part.
I am no expert, but check all the fundamental stuff to ensure you don't start going down the wrong path. Like for example, were the valves set during this process? Did the distributor get moved in the wrong direction when setting the timing? (Like forgetting to ensure the bolt is tight on the distributor, so it won't move during running condition.)
Also, in view of the battery being jumped to start the car, check all your fuses to ensure none are blown.
TibetanT 04-17-2010 10:12 PM
Oh, I forgot to mention this earlier: I personally don't use Platinum plugs because they were really terrible for my car, so I went back to regular copper Bosch plugs.
I experienced the exact same problem you describe here by doing a tune-up maintenance with Platinum plugs. Just my experience with them and not an expert opinion on what to use; just an observation on my part and a personal preference.
Good luck!SmileWavy
Walter_Middie 04-18-2010 06:23 AM
Sounds like a huge vacuum leak. Do you have a pop-off valve? Did the low battery cause a backfire? Is the pop-off valve still sealed?
Drisump 04-18-2010 06:30 AM
If you've JUST changed the wires, check the firing order first.....an easy mistake. Good luck
kodioneill 04-18-2010 06:47 AM
Cylinder head temp sensor?
la975 04-18-2010 07:45 AM
Thanks for all the ideas so far. The plug wire order is OK and the problem started before the wires were replaced. Platinum plugs have been in for several thousand miles and have run good in the past. By the way Bruce Anderson at his tune up class also recommended copper plugs for this year 911. Timing hasn't been changed since it was running good. I haven't checked the head temp sensor yet but will do that soon.
la975 04-18-2010 07:47 AM
Oh, I forgot to mention that 84 doesn't have a pop-off valve and the trouble started before the backfiring which is pretty minor by the way.
MH911 06-01-2010 01:27 PM
Any solution to this problem. I hadn't made any changes. Ran great yesterday on a 200 mile trip to Big Sur. Today I started experiencing same problems as described.
la975 06-03-2010 08:46 PM
Still runs rough at any rpm higher than idle. Idles fine. Have since replaced the cylinder head temperature sensor, camshaft sensor, and speed sensor. All the work so far has made a little improvement but not much. I'll be looking into a air leak next. I've done some looking and there is no obvious leak. Let me know what you find with your car. Good luck.
kodioneill 06-04-2010 10:52 AM
It's possible that the ECU for the Motronics has failed after your battery problem.
kidrock 06-04-2010 02:09 PM
la975,
before you start sending off your ECU for diagnosis, you may want to do a quick check for vacuum leak.
You've already stated that your motor starts and idles fine. With a warm running engine, remove the oil filler cap. If your idle does not immediately stutter and idle roughly with the cap off, you probably have an intake leak somewhere.
Another test is to spray carb cleaner or ether around all intake ports and vacuum hoses while the engine is running. Any hesitation in idle while spraying indicates an intake leak.
I've heard that the intake manifold gaskets get "sucked in" as they age and crack, and are sometimes difficult to pin down when leaking.
If, after all this and you've found no intake leak, your problem will most likely be somewhere in the ignition system.
Por_sha911 06-04-2010 02:24 PM
Have you checked your voltage? Low voltage can make the ECU run wonky.
kodioneill 06-04-2010 02:57 PM
If you read the first post you will see that this all started after a battery problem where the owner jumped the car possibly causing a surge. Unlikely a vacuum leak showed up at the moment he restarted the car.
kidrock 06-04-2010 03:12 PM
yeah, true...but he stated that he wanted to hunt for any leaks, and a vacuum check only takes a couple of minutes, and doesn't hurt anything. Anything can happen...better safe than sorry. :D
MH911 06-04-2010 04:11 PM
LA975,
My car has been in the shop since yesterday and he's scratching his head over it. Yes, he is a Porsche mechanic. I just want me baby back.
I really have a hunch we have the same problem. I'll keep you posted.
kodioneill 06-04-2010 04:17 PM
Why don't you try a new ignition coil?
rusnak 06-04-2010 04:30 PM
Wow, this thread is very messy.
To the OP, can you summarize the parts that you've checked and/or replaced? If it were my car, I'd probably start at the beginning and make sure the battery is fully charged, clean and tight contacts, make sure the dme relay is good or replace with a known good one. Clean the dme ground wires until they are shiny and make sure they are tight. Check for at least 12v to 12.5v at the dme harness or at the ICV harness. Make sure your alternator is working by checking the voltage at the battery with the engine running.
Then proceed to check the fuel pressure, O2 sensor voltage, eliminate the possiblility of the CHT sensor being bad, and check the speed and reference sensors. Make sure the idle position switch is set correctly and working. You can check the AFM (air flow meter) with a 9v battery. Bentley manual has all of these checks outlined in it.
47silver 06-04-2010 06:49 PM
Why did the car need a jump?
What is the voltage at the battery when the car runs?
Sounds like low voltage, i.e. alternator.
la975 06-07-2010 08:14 PM
Thanks for the recent replies. I haven't been able to work on the car but will next weekend and will try the suggestions. To summarize what's been done to date as suggested by rusnak and outlined in the Bentley manual:
-checked the DME connections
-replaced the fuel pump relay and fuse
-visually inspected the fuel pump while running
-checked fuel system pressure
-checked volume air flow sensor output
-replaced rotor, cap, coil, and ignition wires
-replaced cylinder head temp sensor
-replaced speed sensor and reference sensor
-replaced O2 sensor
-checked luggage compartment fuses
-visually checked grounds
-replaced fuel filter
-replaced battery
DanielDudley 06-08-2010 01:56 AM
Get rid of the plugs. They may not be the problem, but I don't think they are helping. Do check the connection to the head temp sensor. They are awfully finicky.
la975 06-14-2010 08:18 PM
Checked the voltage. 14.3 v with no load and 13.8 v with all the accessories on. It was difficult to get a reading since the engine wouldn't rev smooth at 1500 rpm, there was a constant surge and stumble. I didn't get a chance to check for the air leak. the cylinder head sensor connection was tight. I'll follow the suggestions given by kidrock to check for air leaks. Thanks for all the suggestions. I find them very helpful in planning the next diagnostic steps.
DRACO A5OG 06-14-2010 10:14 PM
LA975,
I assume you in L.A. = Los Angeles, if so go to autos=zone and have them test your battery and alternator. their machine can diagnos if it is an alternator issue.
I had similar issues then discovered after many jumps my alternator was shot.
la975 06-16-2010 05:27 PM
Thanks for the suggestion. I'll pop the altenator out this weekend and stop by the auto store and have them check it. The battery is brand new and seems to be fine.
TibetanT 06-16-2010 06:34 PM
Just a thought, but when was the last time the valves were set and the timing checked?
Good luck with this.
jsoderbe 06-16-2010 09:48 PM
Hi,
My car didn't run that bad, and had problems starting it as well. My problem was the ground wire (or whatever you US guys call it...:)) between the gear box and the body. It was intermittent, some day I drained the battery completely, another day it worked perfectly.
After cleaning the connections there is a HUGE difference in how the car performs, when it has enough power in the battery!
Johan
la975 06-19-2010 12:23 PM
RUNNING AGAIN!! After all those parts a couple of squirts of Gumout did the job. Not sure what this issue was but spraying Gumout looking for a air leak solved the problem. Closest I can figure was Idle position sensor or volume air flow sensor had a dirty contact. took it out for a 40 mile run and it ran great, just like before. Thanks for all the ideas and suggestions.
MH911 06-25-2010 08:44 AM
Glad to hear your car is back on the road. My car has been in the shop for over three weeks now and he still can't figure out what the problem is. If my problem ( very much the same as yours in description ) can be resolved as easy as this, I will be thrilled. I just want to get my car back and get back out on the road.
DCinVA 06-25-2010 09:04 AM
The idle position microswitch is a probable cause. This switch tell the ECU when the throttle is closed, and the ECU delivers the appropriate amount of fuel for idle. If the switch fails it may send the "Idle" signal to the ECU even when the throttle is open, which will cause a very lean mixture, and cause the symptoms you describe. To test for the, unplug the switch, and drive it without it connected. This will raise the idle to 1100 rpm, but not harm the engine.
Hope this helps.
Dave
MH911 06-25-2010 11:22 AM
Hi Dave,
I did bring up the micro switch to the mechanic a while back. He was a
little miffed at a arm chair mechanic telling him what to check. Just
said "checked it". I'm getting pretty frustrated here. I'm about ready
to go get my car back and give it a squirt of Gumout and replace the
micro switch my self.
rcaradimos 06-25-2010 02:41 PM
Originally Posted by MH911 (Post 5423537)
Hi Dave,
to go get my car back and give it a squirt of Gum out and replace the
I think your on the right track... get your car out of there. Search: checking idle micro switch. Using a volt meter will tell you if its in open or closed loop; moving throttle just a bit switches mode.
la975 06-26-2010 07:53 AM
Sorry to hear you're still not on the road. One thing I learned from my experience is that the parts can test OK but the connection may be the problem. Something that has been 'tested' may still be the problem. You might check your connections.
DCinVA 06-28-2010 04:19 AM
I suggest you unplug the micro switch, and drive the car for a couple days. If the poor running condition condition goes away with the switch disconnected, replace the switch.
Good Luck.
