-   -   2.4mfi what next? (http://forums.pelicanparts.com/porsche-911-technical-forum/537727-2-4mfi-what-next.html)
gwmac 04-19-2010 06:07 PM
2.4mfi what next?
Traded for this, pulled from a wreck , sat for 8 years that I know of. Pulled the plugs and shot some oil in there and tried to check compression. will turn over but compression seems to be less than 25lbs on the first two cylinders I checked so I did not go on. Any one have any suggestions?
garyhttp://forums.pelicanparts.com/uploa...1271725632.jpg
tharbert 04-19-2010 07:00 PM
I don't think you can assess the health of the engine as it sits on a pallet. The compression may be dicey until you get the thing started and the rings reseat.
So what's the goal here? And what's the budget?
pwd72s 04-19-2010 07:18 PM
From the location of the cold start lines, it's either a '72 or '73 911E...these engines were designed to run on REGULAR grade gasoline of the time..not the higher compression of the earlier years.
Good find if you didn't pay too much...:D
gwmac 04-20-2010 04:16 PM
I would like to be able to assess its condition before going to the expense of sourcing all the missing components and having the MFI rebuilt. Any advice on the best way to proceed?
M491Cabriolet 04-26-2010 05:11 PM
I'd love to have that engine! If you want to get rid of it (seriously), please let me know!
gwmac 04-26-2010 06:14 PM
Sorry I do not wish to sell it, I am hoping to get it running and either put it in the 74 or find a roller. I do not know the best way to proceed without damage to what I have, Anyone like to offer any advice?
g
bgyglfr 04-26-2010 06:33 PM
Why not pull the MFI and the heads and visually inspect it? I would bet that, if the cylinders look good, the crank would be good as well as long as it was stored with oil in it. Just an thought.
