"Der Hellion"
roctor's Avatar
Send a message via AIM to roctor
Question braided coil wire
Hello All, When replacing 30 year old coil connectors. A duplex
wire which was almost nil, had to be cut back. My question. Can this
wire be spliced individually (2=1)? Or will I have to chase down these
wires at the source? Thanks roger
Old 04-22-2010, 03:46 PM
"Der Hellion"
roctor's Avatar
Note: Coil is Bosch. Car is 1977 911S. Roger
Old 04-22-2010, 04:16 PM
The wires only run between the coil, the CD box, and the distributor.
History shows that the white wires break down and ground off to the sheilding. I would make up a harness with all the grounds in one wire and wrap it off.
Bruce
Old 04-22-2010, 06:50 PM
"Der Hellion"
roctor's Avatar
Thanks Bruce! Roger
Old 04-23-2010, 02:47 AM
"Der Hellion"
roctor's Avatar
I've openned the wiring harness to the CDI box. The duplex wires (ground?) tie
off together at plug-in. Should the silver wires connect to the common ground or are
they destination sensitive? Thanks Roger
Old 04-23-2010, 10:19 AM
