one of the great unwashed
patkeefe's Avatar
Green Wire replacement
So, a few years ago, I replaced my green wire with a coax cable (I got the idea from Early_S_Man), so I had a continuous wire from the distributor to the six pin unit. Now, I replaced the configuration with a new green wire, and I need to fab a new Amp Jr connection from the femal end of the new green wire to my MSD box.
Question is: which terminal is which on the female Amp Jr connector on the new green wire. Any know?
TIA!
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 04-20-2010, 09:25 AM
brads911sc's Avatar
Call Barry Hershon at IAC in Detroit... He made the small cable that plugs into the new green wire and right into the MSD connector. Turned out great!If you search for my PMO ITB Install, I have pics of it on there.
TIA!
Pat
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 04-20-2010, 10:43 AM
What did you use for the new green wire? Is it still a shielded cable? I am using the coax, and I am pretty sure it has failed on me (no spark).
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 04-21-2010, 08:15 AM
patkeefe's Avatar
John:
I got a new wire from Pelican, which is a factory shielded cable. I have to build a new coax to the MSD, with an Amp Jr coonnector. My old coax I built was breaking up at the distributor...the bend radius was small.
My original green wire broke on me, and at the time I was too cheap to spend the $65 for a new wire.
Patrick E. Keefe
78 SC
01 Boxster
Old 04-21-2010, 09:27 AM
sudo apt-get purge 930
equality72521's Avatar
The green wire for the 928 is exactly like the 911 except it's about 30" long. I wired mine right to the CDI plug.
--clutch-monkey
Old 04-21-2010, 09:33 AM
Thanks guys, I did get the replacement for the dizzy section from Pelican. I need a long length from that connector to the CDI box. I will look into the 928 wire. I have no problem adding the connectors (already did with coax), but I just need something with some length.
John A.
Old 04-21-2010, 10:01 AM
Can anyone point me in the right direction on the 928 wire? Was it only on certain years? I had my parts guy look on PET, but we weren't 100% sure.
John A.
Old 04-21-2010, 10:17 AM
It costs a lot more but it was worth it to me not to have the plug (I cut the plug off and connected directly to the CDI plug).
928-602-907-00-M100
Porsche 928 Ignition - Page 1
--clutch-monkey
Old 04-22-2010, 02:25 PM
