-   -   stabilizer bar how to (http://forums.pelicanparts.com/porsche-911-technical-forum/537948-stabilizer-bar-how.html)
sneedster 04-20-2010 06:18 PM
I am replacing the bushings for my front stabilizer bar. After much effort I got the bar out of the bushings. However, I am having trouble getting the bar back into the bushings. The manual says to push one end in first then the other. When I push one end in, the bar appears too wide by about an inch to go in on the other side. I am referring to the bushings closest to the front of the car. Any advice will be much appreciated.
Thanks!
Sneedster
JerryL 04-20-2010 06:49 PM
What year / type of bar?? early thru the body or other??
And as always PICS help
Regards
steely 04-20-2010 07:44 PM
agreed a little more info needed. Are you talking diameter? Bentley mentions using Contifix or rubber lube btw but are you talking mechanical obstruction?
James Brown 04-20-2010 08:30 PM
check out the come-a-long, hose-clamp thread, very slick.
