I have same problem on 2000 Boxster. Intermittent whistling from passenger side. Occurs at low speeds, more often when making right turn. Goes away if press or let off accelerator. Volume of sound does not vary. Any thoughts?
Old 05-19-2010, 05:03 AM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
are you sure its not during left turns? if it is there is a simple solution.
install a brunette in the passenger seat....
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 05-20-2010, 09:12 AM
front noise
I have exactly the same problem.Have you found the answer?At a constant speed I hear a humm from the passenger front side.If I lift my foot off the gas ever so slightly it goes away and comes back a few seconds or minutes later.From a stop if I accelerate and turn right I hear it.If I turn right without pressing on the gas it does not do it.My mechanic has no idea and it has been like that for a year now.It is just bugging.I believe it is some sort of fuel problem.Any help would be appreciated.Thanks
Old 11-26-2010, 10:05 AM
stephens_kj's Avatar
Could be worse, I drive an SC and hear lots of noises all the time.
1983 911 SC 3.0
1978 Ford Capri X Pack 3.0
SE OM Flyer 2011(26), SE PK Ripper 2010 Retro Loop(20), Mongoose SGX 1999 Anniversary(24)
Est 1971
Old 11-26-2010, 10:22 AM
Gus Berges's Avatar
In the 996 I had, it turned out to be the fuel pump starting to go bad... 99% sure its the culprit here.
Now: 2013 Cayenne GTS
Ex: 1999 C2, 2004 Cayenne Turbo, 2002 C4S, 1999 BMW M Z3 Coupe, 2013 Audi RS5
Old 11-26-2010, 02:26 PM
