Weber Carb Differences
Does anyone know the differences between the weber 40 IDTP 3C1 carb and the weber 40 IDA 3C? Are the parts interchangable? Thanks for you help.
Tom
1972 911T (with 3.2), 1985 930-EFI Conversion (in progress), 2016 Cayman GT4
Old 04-27-2010, 07:24 AM
E Sully's Avatar
Weber Carbs Diff Between IDA IDT IDTP
Ed
1973.5 T
Old 04-27-2010, 08:31 AM
Hi Tom,
The parts are basically interchangable; the differences lie with the size and position of the transition ports in the bore just below the throttle plate.
The IDT carbs were calibrated more for emissions and a have a leaner "tip-in".
One should always use the same series of carburetor on both sides of the engine.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-27-2010, 09:44 AM
1QuickS's Avatar
Not only are the transition ports different but the air correction bleed jet for the progression circuit is larger (leaner) than the IDA, IDS and IDAP carbs but this can be changed rather easily. Otherwise all the above carbs are basically identical in performance.
Paul Abbott
PerformanceOriented.com
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 04-27-2010, 09:04 PM
