-   -   Bursch headers interfering with omega spring (http://forums.pelicanparts.com/porsche-911-technical-forum/538938-bursch-headers-interfering-omega-spring.html)
pcar9119 04-25-2010 03:26 AM
When setting up my clutch, I noticed that the omega spring was hitting the header. Is this common, or am I doing something wrong. Thanks...
brads911sc 04-25-2010 06:28 AM
Common with SSI's. Just hammer down the lip to give yourself alittle extra clearance.
pcar9119 04-25-2010 06:43 AM
Can you show me a pic? The only thing to hammer would be a primary, from what I cam tell. These are headers, not exchangers on them.
pcar9119 04-29-2010 10:46 PM
Noone else has had this issue. I hope it usn't just me...
lindy 911 04-30-2010 06:46 AM
I have a '78 SC with Bursch headers and there is about 2" clearance between the Omega spring and the closest primary.
Lindy
TechN8 06-16-2014 06:38 AM
Sorry to resurrect an old thread, but I have the same issue. What did you end up doing to avoid this?
ganun 06-16-2014 06:57 AM
See if there is plenty of clearance to remove the left lower valve cover.
Bursch made many headers. Call Doug to make sure you have the right one.
I had to talk to him to make sure I had the right one for a 3.2 that would accommodate an O2 sensor.
dicklague 06-16-2014 08:57 AM
call Doug Robinson......Horsepower Engineering in Pasadena, or Google Bursch. Good guy. has a 74 911 and a long time hot rodder/Bonneville guy.
