-   -   8 and 9 Fuchs and tire fitment. Options are running out! (http://forums.pelicanparts.com/porsche-911-technical-forum/538971-8-9-fuchs-tire-fitment-options-running-out.html)
KTL 04-28-2010 09:18 AM
Remember that the aspect ratio (55, 50, 45 etc.) is a percentage of the width (205, 225, 245, etc. So a 205/55 has a theoretical sidewall thickness of 205mm x .55 = 112.75mm. The 245/45 has 245mm x .45 = 110.25mm Difference of about 2.5mm is pretty small.
However the 245/50 has a 122.5mm sidewall = 10mm gain, more significant
Steve W 04-28-2010 10:26 AM
Originally Posted by BarryJB (Post 5321235)
Steve, on the fenders, did you just give them a gentle two-handed heave-ho, or use some more exotic tweaking technique? I'd like to do that on the rears on mine for sure...
I think I just used my hands and pulled them. You could try a pipe leveraged against the tire, but you must back the fender from the inside or risk dinging the sheetmetal.
BarryJB 04-28-2010 02:55 PM
I'm going to try this, better than messing with camber. Your mention of backing jogged memory of an old post about using a baseball bat and a flexible sheet of UHMW polyethylene material as low-friction backing to roll up fender lips... I'm guessing same approach with a somewhat thicker but still flexible sheet would work well to reshape the fender arches. But I need such a tiny amount, I'll try the two-handed heave-ho first though, taking care not to visualize creating a nice sharp vertical crease ;¬)
Thanks!
