Michelin TB15 tires
Will Michelin TB15 18/60-15s fit on a 9x15 inch rim? Planning on using the 9 inch rim on the fronts and 11x15s on the back with the TB15 26/61-15. Been looking for a while now and coming to the conclusion that a matching set for these rims are as common as a unicorn.
Dave 1984 911 M491 1986 911 Hotrod |
Happiest when Tinkering
and expensive! I have 10x15's and considered these for a bit decided to go to 17's so I could upgreade the brakes
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
You've probably already seen this?
1983 AUDI Turbo Ur quattro 1987 PORSCHE 944 turbo |
Thanks for the chart. I have seen a version of it on the Michelin website. I was hoping someone would say that the 18/60-15s could be used on a wider rim than recommended.
It could be made to work, but I think it's going to look a bit odd. The section width (215mm) is 1/2 inch narrower than the 9 inch wheel width. Like you say, the choices are few and far between.
