Trunk Questions
I have a 1973 911 that is in a constant state of refurbishment. In the front trunk a few things that seem a bit ...odd.
1. What holds down the spare tire? There is no bracket or clamp on the gas tank 'hump.' When I got the car, the tire just sat there. 2. What holds the windshield washer tank in place? Is there supposed to be some kind of gasket around the neck, and is it supposed to be suspended from the hood threshold? Or is there some support under the tank or a strap I'm missing? 3. Where is the jack and the toolkit supposed to go? I've been wedging them in front of the spare tire, but I'm thinking that there must have originally been a way to strap them down. 4. Is there supposed to be some kind of shield or cover in front of the relay panel just aft of the fuse box in the forward part of the trunk? Thanks for the help in advance, and any pictures and/or part numbers would be most helpful. |
Jim Sims provided this picture: http://forums.pelicanparts.com/uploa...1105316939.jpg Quote:
-there is a fiberboard formed shield in front of the relay panel
-spare just lies there -washer bottle is held in by the three prongs in the chassis inside the trunk, and the neck of the bottle throught the hold-down bulkhead - (I made mine into a washer-bottle-delete option, and plugged the hole with some thick rubber foam padding) -do you still have the metal battery straps and the rubber charcoal canister tie down? Bill K http://forums.pelicanparts.com/uploa...1272459954.jpg |
the three prongs are circled on the lower right - barely visible
Bill K http://forums.pelicanparts.com/uploa...1272460371.jpg |
Tool kit, all I've ever seen is to wedge it in front of the spare next to the spare quart of oil. |
Bill K |
Memory ain't what i used to be... |
Does anyone know the model years the rubber jack wedge was used by Porsche? Thanks Lynn
washer bottle bracket
heres a before and after. i fabricated it myself but i think is still available from porsche
http://forums.pelicanparts.com/uploa...1272493833.jpg http://forums.pelicanparts.com/uploa...1272493856.jpg |
Thanks for the help guys. I'll look for the prongs for the washer bottle. I don't have the wedge or strap tie down for the jack, since I had to replace the suspension pan due to car cancer. The replacement sheet metal didn't have anything 'extra' on it. That piece for mounting the wedge looks like it'd be pretty easy to make, anyone know a source or have a picture of the actual wedge?
Bkreigsr, I thought there was supposed to be a cover over those relays. I do still have the charcoal canister and straps, but no battery hold-down straps. |
jason,
my picture is of the washer bottle "prongs" located on the left side. i don't know of the jack wedge and am curious myself what it looks like. bob |
| All times are GMT -8. The time now is 03:44 PM. |
