-   -   MFI Regulator Housing connection (http://forums.pelicanparts.com/porsche-911-technical-forum/539741-mfi-regulator-housing-connection.html)
marksearls 04-29-2010 06:44 AM
Does anyone have a picture of the 1972/3 MFI regulator housing connection (911.108.015.00)? I know one end connects to the flexible rubber (top) hose with a clamp and the other connects to the heat exchanger (bottom) but it seems there is a way to fix the regulator housing itself to the engine case. Am I missing something?
Thanks in advance, Mark
356RS 04-29-2010 08:13 AM
The regulator housing bolts up to the side of the TB plastic stack via a 90 degree black metal bracket. There are 3 threaded holes in the TB plastic stack near the top front left hand side. The metal bracket fits around the throttle crossbar in that area of the plastic stack. Also there are 3 threaded holes on the side of the regulator housing for the black metal bracket to bolt up to. Yes, you might be missing the bracket. I can post pictures if needed.
marksearls 04-29-2010 08:46 AM
missing bracket
Mark, that would be great if you could post a picture of the missing bracket, and a part number, if you have it so I can purchase it.
Thanks, Mark
356RS 04-29-2010 09:19 AM
Part number is: 911.108.325.00 and is called "Fastening plate for regulator housing".
http://forums.pelicanparts.com/uploa...1272561529.jpg
http://forums.pelicanparts.com/uploa...1272561549.jpg
http://forums.pelicanparts.com/uploa...1272561568.jpg
