El_Mecanico's Avatar
Smelly exhaust
I gutted out the cat and now the exhaust stinks. It doesn't smell like its running rich though. Kind of a rubber smell any clues?
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 04-29-2010, 05:51 PM
steely's Avatar
My nose may not be tuned, but mine has a definitely oil smell I attributed to being normal for an air cooled oil drinker. Cat was off when I got mine. Somebody likened it to older volkswagons. is this what you mean or is it different? When I was a kid, I hung out around an old train yard, almost similar smell.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-29-2010, 06:29 PM
abit off center
cgarr's Avatar
Bad Gas?
______________________
Craig
G2Performance
Old 04-29-2010, 06:34 PM
My friend told me its smelled while following me. Maybe your right! It doesn't show much smoke though. Maybe I need to overhaul? She had 180 or 190 on all 6cyl for compression. I guess the CAT hides problems.
Old 04-29-2010, 06:47 PM
deshetlr's Avatar
Mine does the same thing since installing my M&K. The general consensus is it is running a bit rich. However I just did an emissions test with no problem.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 04-29-2010, 07:08 PM
Talewinds's Avatar
M&K premuffler here too. I just thought it was that yellow insulating fiber inside the premuff burning off, but months later the smell is still there when the car's running and warm.
It's a very odd scent.
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 04-29-2010, 07:19 PM
Hi,
LOL,...now you know more about what cats do on these cars,....
For us old guys who were around when there was no such things as catalytic converters, thats a normal smell (slightly rich). Enhanced by the obnoxious smell of today's gasolines, you are experiencing the reality of an "open" exhaust. Back in our time, pump gasolines smelled a bit like today's race gas (unleaded) so it wasn't all that unpleasant.
As long as the AFR's are OK, its something you live with when the cat is removed. If its too much to take, using 100 octane unleaded race gas will make things more "fragrant" to a motorhead,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-29-2010, 07:26 PM
deshetlr's Avatar
Steve,
Is there a DIY way to check the AFR? While I have been considering a pre-muffler and SW chip I have not removed the cat as of yet, I just bolted on an M&K muffler. I do love the way it runs though.
Scott
Old 04-29-2010, 07:53 PM
Originally Posted by deshetlr View Post
Steve,
Yessir, there sure is.
Two ways: take it to a Dynojet facility and buy a few dyno runs. They usually have a good wide-band sensor setup that will display WOT AFR's on the graph. The other way is to buy something like the Innovate LM-1 hand-held AFR meter. This enables you to check & monitor this any time you wish. They even make a nifty in-dash unit.
For accurate figures, you will need to install an additional oxysensor bung by the factory one (pre-cat) for the wide-band one.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-29-2010, 08:05 PM
tobluforu's Avatar
Innovate also makes a device that inserts into the muffler and works pretty damn good, but a bung is the way to go.
You should drive behind my 72 mfi with an M&K dual tip muffler, no back pressure for the most part, and damn does it stink.
Old 04-30-2010, 04:31 AM
