Asking for Sunroof Help Again
When I removed my sunroof headliner, everything above the headliner itself had become all bunched up. The glue had long since given up the ghost. Consequently I am having a hard time figuring out where the various pieces of felt and vinyl need to go when I re-glue them. It is obvious that the big piece of vinyl with the slit in it (with the black felt still attached) must go directly above the headliner (but under the frame), and that a sewn-on piece of the headliner fits through that slit and somehow attaches to the middle bar of the frame. Since I don't see any old glue on the flap from the liner, I am not sure how it attaches. There is also a long strip of vinyl, and I am not sure where that goes.
I have attached some pictures and would be eternally grateful if anyone could point me in the right direction. The 1st picture was taken before I removed the panel. ![]() The 2nd picture is my idea of where the pieces probably go (though not too sure about the long vinyl strip goes. Since there is still a piece of beige felt attached to the bottom of the front and rear bars, I assume that the other beige felt piece attaches to the bottom of the middle bar. ![]() Can somebody tell me where that long vinyl strip goes?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
I've since figured this all out. the black vinyl strip goes on the bottom of the middle metal bar of the frame. The reason for his and for the other big black vinyl piece with the slit in the middle is that, when you look up at the finished sunroof headliner which is perforated, you want to see black, not white through the holes.
