Before I start using penetrating lubricants near my clutch, I'm wondering if anyone has seen (and successfully fixed) a seized clutch in the 901 transmission ('71 911e)?
It was sitting for about 2 years in Vermont before I started it, but I can't get the clutch to disengage. There's some rusty accumulation present, and I am hesitant to muscle through it without consulting you folks first. Any help would be appreciated. Regards, charlie |
Can you put it in gear when it is off?
72 911 Although it is done at the moment, it will never be finished. |
I had the same thing with my 912 after it sat in a barn for years. I jacked it up, just so the wheels were off the ground, started the car in gear, and dropped the jack. Broke the clutch loose
edit: be sure two people are doing this
-mike |
Been there before. If the car runs, get it in 2nd gear and drive around the block a few times. It should break loose. A little safer than the jack drop but not as exciting.
Mark Jung Bend, OR MFI Werks.com |
a variation of the above post... get it warm so it starts well, clear the way in front of you for 100 ft or so, shut it off, put it in 2nd, clutch pedal to the floor and keep it there, start car and as it gets rolling, go on and off the throttle a few times until it breaks loose.
I can get it in gear with the engine off, so I'll give your suggestions a shot this afternoon. Will let you know results.
Thanks for the quick reply. |
I would rather be driving
I have used the same procedure on my car as well.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Worked perfectly, thanks guys.
| Tags |
| 1971 , 911 , 911e , clutch |
