Question on the under-cowl fuel evaporative cannister on a 72
How is the cannister held in place? Is there a rubber strap used to hold it in? I looked at PET, which shows the cannister, pn 902.201.062.22, but no securing piece.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
If you are referring to the little box near the instruments, it is held in place with a "rubber band" p/n 901-201-618-02. If mine broke, I would get an O-ring of the correct size to replace.
Harry nailed it...here's a diagram of the whole system: I believe this is the 1970 version...but no real differences in '72.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Band.
If you're talking about the canister near the battery, then YES it does have a rubber strap about 3/4" wide that holds it to a bracket.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Yes, I'm referring to the box by the instruments. Thanks for the info, Harry. The charcoal cannister by the battery is still strapped in place, so I'm okay there.
