rboylan's Avatar
Warren, 1 More Voltage Regulator Question
Warren,
In an earlier post you stated that if the Black DF wire was connected to the back of the alternator, it needed an external regulator. Since I just refinished the fan, I'm trying to determine this without pulling the alternator. I did learn this:
The engine harness has a 3 prong plug coming off it which appears to connect to a noise suppressor(sp?). There is a Brown, Light Blue, and Black on the plug. The black is marked on the plug DF . Can this be an indicator or is it mandatory to pull the alternator ? Thanks.
1969 911E Albert Blue 1970 911E Iris Blue
1970 911T Signal Orange 1972 911T Gold Metallic
1981 930 Arctic Blue 1981 930 BB Auto(on ship)
1987 930 Cassis Red Met 1996 993TT Black
2007 997TT Cobalt 2017 991 Turbo Cab
Old 12-12-2001, 06:27 AM
Early_S_Man's Avatar
Porsche Crest
Rich,
If that is the 3.3 engine harness, then, it definitely had a VR when it left the factory. Sounds like you do need to pull the alternator again to see if it has been changed out.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-12-2001, 06:39 AM
rboylan's Avatar
Warren,
Just so I'm certain here: Your feeling is that the 3 prong plug indicates the car left the fasctory with an external regulator ? Thanks again.
Old 12-12-2001, 11:20 AM
Yes, Rich, the post-'73 Voltage regulators and noise suppresors used that same 3-pronged plug! The noise suppresor can be disconnected and the engine cable could be plugged directly into the VR if necessary for troubleshooting purposes and run without a suppressor, if it failed.
Warren Hall, Jr.
Old 12-12-2001, 11:35 AM
Senior Member
Superman's Avatar
Warren, you can ride with me on any long trip.
Mocha 1978 911SC. "Coco"
Old 12-12-2001, 02:10 PM
