-   -   Replace clock with voltmeter (http://forums.pelicanparts.com/porsche-911-technical-forum/540713-replace-clock-voltmeter.html)
Justin@Athens 05-04-2010 06:36 PM
Hey guys,
I am looking to replace my clock with an analog voltmeter and was wondering if any of you have and input on what unit might be best?
I believe that is a 3" guage, but I can only locate smaller diameter units on amazon.
I note that pelican sells a unit, but its $44!!!
James Brown 05-04-2010 06:50 PM
Try Palo Alto speedometer or North Hollywood Speedometer for a nice looking one. Or replace the oil quantity gauge with a volt meter. Keep the clock.
gulf908 05-05-2010 03:09 AM
Justin,
This is what I did with mine.
I prefer to keep an eye on the charging rate in the batteries rather than watching the time !
Quite some time ago I bought a clock blank from the local Porsche dealer when they weren't too pricey.
I subsequently went to the local VDO store and picked a voltmeter I liked that was closest to the other instruments in appearance.
This is the result.
Going the OEM clock blank way may be a bit more $pendy these days but it looks a bit more authentic to me.
BTW,the voltmeter has saved my batteries from frying twice due to an overenthusiastic regulator.
HTH,
Dennis. :)
http://forums.pelicanparts.com/uploa...1273054071.jpg
http://forums.pelicanparts.com/uploa...1273054131.jpg
woland 05-05-2010 04:06 AM
Justin
Considering that the 911's oil level gauge is quite inuseful, I'm looking to turn it in an analogic voltmeter using a variable resistence connected with a positive wire.
In this way I'll keep the splendid Porsche clock with his white arrow that tells me the trip duration.
I let you know the results when done
JeremyD 05-05-2010 06:09 AM
I had North Hollywood convert my tach and install a voltmeter
http://forums.pelicanparts.com/uploa...1258841347.jpg
Winter 05-05-2010 06:29 AM
These are some nice looking solutions. I'm not there yet with my ongoing improvements to the much neglected '75, but will be at some point. I'll keep what you guys have done in mind. Good work and thanks for sharingSmileWavy
Tom '75 targa
Drdogface 05-05-2010 07:09 AM
Originally Posted by woland (Post 5333854)
Justin
I did just that and it's worked out well....but pricey. I think I uses No. Hollywood. I like having the clock there for the original look if nothing else. :cool:
lin7310948 05-05-2010 07:35 AM
voltmeter
several solutions but i prefer the factory gauge look. i do not use the clock as i use it for a fuel pressure and and oil temperature gauge combination gauge...gauges converted by n. hollywood speedometer.http://forums.pelicanparts.com/uploa...1273070102.jpg
poorsche930 05-05-2010 12:14 PM
Thats bad ass! I have a 930 with the boost gauge at the bottom so it would get cluttered for me. Maybe they can convert my oil level into a volt meter?
JeremyD 05-05-2010 12:27 PM
I'm having them do that now with the gauges from my 1974 911.
lhoudyshell 05-05-2010 02:23 PM
Take a look at Bigmarkdesign, he has a really great stock appearing voltmeter that he installs in the lower part of the tack, at a very reasonable cost. Did mine and I am very happy with it. Try a search here may turn up the info you need. Lynn
kodioneill 05-05-2010 02:49 PM
I like! What did that cost?
JeremyD 05-05-2010 06:55 PM
Call North Hollywood - they are very reasonable. I didn't just get that done = so not sure what the cost to just do that is.
gbradcsi 12-05-2011 05:21 AM
Voltmeter instead of Clock 1987 Porsche 911
I went through two clocks which are not cheap. i read the article regarding swapping out the clock for a voltmeter and thought about doing this. i should have done it sooner, because my alternator went out last week 76 miles away from home so i needed a tow.
i used the outer metal ring and the rubber gasket/grommet that hold the clock in the dash from my again non-working clock for this project. i purchased the same VDO Voltmeter as shown on this forum. i bought a set of hole saws, plywood, black spray paint, and a black vinyl/plastic.
i purchased a non working clock on ebay for $25, in case i sell the 911 in the future to make it original again. if i had to do the job over again i would have made it a little differently, because it would have saved me a lot of time. it turned out excellent.
Joe Bob 12-05-2011 06:15 AM
Wesstach, aircraft gauge manufacturer....
a_bayuga 12-05-2011 02:10 PM
NH VDO Clock
Got mine from north hollywood. I do not recall the price though.
http://forums.pelicanparts.com/uploa...1323122878.jpg
http://forums.pelicanparts.com/uploa...1323122912.jpg
http://forums.pelicanparts.com/uploa...1323122936.jpg
KTL 12-05-2011 03:00 PM
Yep. I agree Mark does very nice work. His website is New Vintage USA
New Vintage USA-Our Original Porsche Work
He is "marks914" here on Pelican
dshepp806 12-05-2011 04:02 PM
Thanks for the info here,...
I'm up for exorcising my clock on my '89. It has worked flawlessly during it's six years with me...(I surely would stow it away),..and make use of a voltmeter in it's place. Maybe a combinational gauge,..we'll see.....had been using R/L detector to monitor voltage (saved my arse' on an alt/reg going bad)....am coverting R/L detector to wireless or hidden cables to rid myself of (exposed) cables.......will be cool to NOT have to occasionally check the cig lighter output DC level vs. the actual battery (compensating for the differential-while "monitoring"------,..albeit small, but still existent).. A voltmeter with the rest of the instrumentation will be nice.... (usefully: i.e., REQUIRED).
It's amazing that they would omit such crucial voltage monitoring,........I can assure you that nothing lit up my (stock) dash when that reg output +16.0 volts for a brief moment,..caught (and alarmed) when it happened by the R/L detector.....then it happened once more on a different day....BAM,..fresh alt/Reg......DONE. Found the original 1989 alternator in my 1989, BTW!!!!! Guess it was done after all of those years of service (ahem).
Will check this guy out,...thanks, again.
BEST!
Doyle
Balisong 11-05-2021 08:42 AM
I am wondering if I added a volt meter if I might not notice a spike for a while. Has anyone added a warning light somewhere instead? Would be interesting if someone made a replacement cigar lighter that was a voltage warning lights with a buzzer perhaps.
darrin 11-05-2021 08:59 AM
lots of volt meter options for the lighter socket. See, e.g. https://www.amazon.com/Cigarette-Lighter-Voltage-Digital-Voltmeter/dp/B00UCEAKYU
