82 sc idle osculation
my 82 911 runs pretty good, however, the idle is 1k and pulsates up and down ever so slightly. it is also hard to start when hot or cold, the exhaust is very harsh smelling and burns my eyes. i just had the intake gaskets replaced and the o rings on the fuel inj.
i would also like to know what a good cheap way to go for a better exhaust. i have heard of muffler bypass, any other ideas?
Old 07-23-2011, 07:38 PM
Eschews Obfuscation
dhagood's Avatar
i'd have to say that all my osculation was with marked intent.
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 07-23-2011, 08:49 PM
Scott R's Avatar
You have a mixture issue, whats causing it? It could be you fixed a problem with the new gaskets and now you just need the mixture corrected.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-23-2011, 09:13 PM
im kinda new at this
how and where do i adjust the mix
Old 07-23-2011, 09:17 PM
my bad
oscillation
Old 07-23-2011, 09:19 PM
This is normal and if the idle is rock steady, the lambda system is not working properly.
Hard starting cold and hot are usually different problems. Start by checking system, control and residual fuel pressures, the CSV and TTS, the throttle microswitches, then the lambda system test routine with a dwell meter at the test connector
Paul
Old 07-24-2011, 04:49 AM
Nine9six's Avatar
...Can you quantify, "ever so slightly" in hundreds of RPM?
I disagree, that a hunting idle is normal.
However, an idle that fluctuates, "ever so slightly", could indeed be normal
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 07-24-2011, 07:08 AM
thats just a symptom, i also have to pump the gas to get it started when is warm or cold
Old 07-24-2011, 08:00 AM
CIS troubleshooting..........
ynotony1966,
You don't need to pump the pedal accelerator to start a fuel injection system. That method applies to carburated engines. You got more than just an air leak/s and need further inspection. Two (2) things I would do to locate the problem/s:
----pressure test the system for air leak/s.
----check fuel pressures (control, system, and residual).
----if the 2 above tests are good, proceed to have your gas exhaust checked with a gas analyzer.
Never tweak your air mixture setting unless you could confirm that you don't have an existing vacuum leak in the system. HTH.
Tony
Old 07-24-2011, 08:45 AM
Lorenfb's Avatar
"the exhaust is very harsh smelling and burns my eyes."
It's obvious that the mixture is too rich:
1. The fuel distributor mixture screw is set incorrectly.
2. The warm-up regulator is not functioning properly.
3. If it has a Lambda ECU, if may not be functioning properly
or the enrich switch is not opening or the O2 sensor
is grounded.
4. The fuel pressure regulator may be bad causing
too high of a system pressure.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 07-24-2011, 09:13 AM
Scott R's Avatar
Put your location in your profile or something. It's likely someone near you has the tools you need to check this. For instance here in Denver I have the gauge set, gas meter and dwell computers to loan out.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-24-2011, 10:10 AM
will do thanks
Old 07-24-2011, 10:29 AM
