Simple Distributor Part Needed for '82 SC
After the recent discussion here regarding distributor maintenance, I decided to follow suit and lubricate the thing. Long story short, I decided to also "fix" one of the two clips that hold down the distributor cap and I guess all the heat cycles made it brittle.
Anyone have a suggestion for me as to where I can get a replacement clip for less than the $650 it would cost to replace the distributor? I've already checked with our host. Thanks, |
If Pelican can't get it call Stoddard
Thanks - I'll give Stoddard a call in the morning.
Okay guys,
I've been looking for this $%^*&$* part for a while now and the best I can do is parts from a 2.7 distributor. Can anyone tell me if the clips that hold the cap on the distributor from the 2.7 will fit my SC distributor as well? Thanks, |
Mark.
Is there any way you can post a close-up picture of a side view of your remaining good clip next to a machinist's rule? If so, it ould help to give you an answer, since I have both 2.4 and 2.7 disributors here. And, several VW Beetle dizzy's, too. There is also a possibility that the spring clip from an air-cooled VW distributor would also work! It does not have the long finger-grip tab, but that could be removed and pop-riveted to the VW clip ... it is the spring part that is important. If the length is correct, the VW part could be used directly, but a screwdriver or other prying device is needed to remove the cap, once the clip is secured. |
Thanks, Warren,
I'll post the pic. you suggest when I get home tonight. |
mark, i just happen to have an old junk dist with one clip still on it. give me your address and i'll send it to you.
1 Attachment(s)
Warren,
Here is the photo (newbie thinks) and I would be curious as to 2.7 compatibility. I have taken John Walker up on his most generous (as usual) offer to send me the clip and get me back on the road.... Cheers, |
Mark,
The 2.4/2.7 clips are smaller. From 'tangent' point to 'tangent' point ... where yours appears to be 1-5/16" ... mine is 1-1/8". Nice going, John! |
Some people are leaders in turning this part of the world into a class act.
Warren,
Thanks for checking for me - I learn more every day about this project. Ron: Well said. My sentiments exactly. It's not even the first time that John Walker has (unsolicitedly) bailed me out. What a guy!!! I only wish I was closer to Seattle to have such a stand up wrench! |
Hello
Check your local junk yards for other Volkswagen, Mercedes or BMW cars from that periode. Also some Alfas, Maserati and so on shared the same izzy bites. Grüsse |
| All times are GMT -8. The time now is 05:34 PM. |
