skids
Irratic Revving
I have an 87 911 and every once in a while when I come to stop and the car is idling it keeps revving up and down for a while then settles back down. I'm thinking its the idle control valve, but is there anything else I should consider before a buy the valve?
Thanks,
Old 05-06-2010, 07:02 PM
You can try and clean the valve before you replace it. I have heard it has worked for a few people here.Hope that hlps.
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 05-06-2010, 07:19 PM
Northern Motorhead
wildcat077's Avatar
Skids,
I'm having the same issue with my 89...
I removed the ICV valve and cleaned it with brake cleaner and blew some air through it,although it didn't help any.
Check your vaccuum hoses,the clamps become loose over time !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-07-2010, 01:59 AM
skids
I tried cleaning it a few weeks ago as well and it didn't work for me a as well. I'll check for any leaks.
Thanks guys,
Old 05-07-2010, 03:44 AM
twistoffat's Avatar
Propane or Carb cleaner can help speed up the process of temporarily sealing the leak to allow location.
Old 05-07-2010, 04:05 AM
muck-raker
kidrock's Avatar
do a search on the thread called "idle bounce"...extremely informative.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-07-2010, 02:13 PM
too high idle speed will do it. also, listen for the clicking from the micro-switch on the left side of the throttle housing when you manually open and close the throttle. the switch tells the computer to activate the ISV when the closed throttle hits the switch.
206 637 4071
Old 05-07-2010, 03:12 PM
