my new warning lights
After seeing an engine cook itself at the track after throwing fan belt, I decided that if I intend to keep on participating in DE events I’d better install a better warning light system. As we all know, it’s almost impossible to see the factory oil and alternator lights, especially with a 350mm steering wheel and also while focusing on the track at 100+ mph. There are solutions already out there like the big red light but I wanted a more factory look. I also wanted two separate lights to discriminate between an oil pressure problem and an alternator problem/thrown belt. So here’s what I came up with!…..
http://forums.pelicanparts.com/uploa...1273284189.jpg http://forums.pelicanparts.com/uploa...1273284335.jpg Disassembled clock and two 1" LED warning lights from Speedway Performance http://forums.pelicanparts.com/uploa...1273284395.jpg http://forums.pelicanparts.com/uploa...1273284410.jpg Using the clock's Plexiglas face, I used a dremel to cut out the holes and spray it black. If I were to do this project over again, I probably use another piece because of the noticeable hole in the center. http://forums.pelicanparts.com/uploa...1273284610.jpg http://forums.pelicanparts.com/uploa...1273284621.jpg http://forums.pelicanparts.com/uploa...1273284632.jpg The last pic shows the lights on but does not do them justice. They are pretty bright! |
Very nice.
I will do something similar, but using smaller lights in between the gauges near the top....if that makes sense. I post some pics when I am complete. Will have gen/fan belt, low oil pressure and low fuel level warning lights installed. |
Nice, I like it...
This is what I did - I use the clock. http://forums.pelicanparts.com/uploa...1264920427.jpg |
| All times are GMT -8. The time now is 09:30 PM. |
