-   -   901 clutch squeak when pedal released (http://forums.pelicanparts.com/porsche-911-technical-forum/541320-901-clutch-squeak-when-pedal-released.html)
chris68 05-08-2010 05:59 AM
Hi all,
The squeak is only present after the engine has warmed up and goes away when I press the clutch pedal.
Any thoughts?
Thanks,
Chris
Grady Clay 05-08-2010 06:07 AM
Chris,
If the ‘squeak’ is at the pedal, the fix is straightforward. Install new plastic bushings at the pedal assembly – there are three pairs. This is a good ‘Saturday project’.
If it is in the tunnel, a new lubed cable is in order.
If in the rear it can get more complicated.
Best,
Grady
