Model Citizen
Master Cylinder - brake light switch
I did a search, but this question wasn't really addressed.
Pelican has the master cylinder I need, except it comes with 3-prong brake light switches, I need 2-prong brake light switches. The host is out of stock on the proper switch. Simple question - can I reuse my working switches in the new MC? Thanx
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
The short answer is yes you can, but you can also use the three prong switch...There are a couple of links in these threads that should help...
Brake light switch connector spacing problem 86 carrera brake lights
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 05-09-2010 at 12:57 PM.. |
Model Citizen
Thanks, AJ. This is exactly what I needed.
