A question concerning Wevo shifter installation
Hi mates ,
I installed a Wevo shifter lever , and i noticed that the cup bushing is not completely sits in his location : see pic joined. You can noticed so that i have an intermediate" plate " between the aluminium body that receives the Wevo and the ground ; approximatively 1 cm of hight , and this part is a factory one, that figures with the original mounting. My question is to know if others owners of Wevo shifter have the same intermediate plate , or if i must remove this part to have the cup bushing fitting completely in his location on the tube. I tryed without this part , but it seems do not working at all. All imputs appreciated , Cedric. http://images1.hiboox.com/images/181...495f32335f.jpg |
Ok , that's solved : i removed the intermediate plate and that's okaaaaaaaaaaaaaaaaaaaayyy !!!!
I precise all the bolts must be changed for shorters ones , to bolt the body on the ground. |
| All times are GMT -8. The time now is 12:18 PM. |
