Quick tranny assembly question??
I'm almost done and want to make sure that the pin goes in the right way and doesn't fall in. Their is a thick end and a tapered end. is this positioning correct? thanks Doug
Doug 97 C2S 993(last one) 95 993 cab- 85 911 M491 87 944 Turbo- 70 914-6 63 911 |
This is the pin that goes into the top of the tranny cover and pushes into the reverse gear unit. I cant find any material explaining which end goes into the tranny? Both ends are quite different. thanks again for looking. Doug
thin end goes into the switch #2 in the pic
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
if you put the thick end to the switch, it jambs in there and the reverse lights stay on.
Thanks guys , I'm finally finished and can button this up. I got a lot of helpful advice from several of you that made the rebuild a great learning experience. much appreciated . Doug
