-   -   Is there a "best way" to store tires? (http://forums.pelicanparts.com/porsche-911-technical-forum/541668-there-best-way-store-tires.html)
JonT 05-10-2010 10:57 AM
I'm going to be long a couple sets of tires that may sit for a year or two most. What is the best way to store these in my garage?
tonythetarga 05-10-2010 12:35 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/73885-storing-tires.html
motorcop 05-10-2010 04:52 PM
I store mine on their sides with a piece of 1/2 plywood between each one. They are also mounted on rims with a few extra pounds of air in them. Been doing it this way for years with no issues.
80-911SC 05-10-2010 05:46 PM
tire rack has some very reasonable racks on there site
HunterVonWurst 05-10-2010 07:35 PM
I made a tire rack out of 2x2's and Simpson Strong Tie brackets. If you can weld, this can be made in 1 hr. or less:
http://www.madebysei.com/Tire_Rack.jpg
Whose car is this?
http://forums.pelicanparts.com/uploa...1216516817.jpg
Tim K 05-10-2010 07:45 PM
Originally Posted by HunterVonWurst (Post 5343988)
http://forums.pelicanparts.com/porsche-911-technical-forum/539919-jack-olsen-my-hero.html
HunterVonWurst 05-10-2010 07:48 PM
Originally Posted by Tim K (Post 5344003)
jack olsen
That's what I thought, but didn't recognize it with that tail. Never saw a pic of that car before with the wing (or the tire rack). :eek:
Kevin Stewart 05-10-2010 07:51 PM
put them in black trash bags so no lights gets to them, also put them were no electric motors will be used, drils and such give off ozone that damages tires, Kevin
HunterVonWurst 05-10-2010 08:07 PM
Ozone isn't believed to be an issue with modern tires:
Ozone Cracking
Ozone gas attacks any polymer possessing olefinic or double bonds within its chain structure, such as natural rubber, nitrile rubber, and styrene-butadiene rubber. Products made using these polymers are especially susceptible to attack, which causes cracks to grow longer and deeper with time, the rate of crack growth depending on the load carried by the product and the concentration of ozone in the atmosphere. Such materials can be protected by adding antiozonants, such as waxes, which bond to the surface to create a protective film or blend with the material and provide long term protection.
Ozone cracking used to be a serious problem in car tires for example, but the problem is now seen only in very old tires. On the other hand, many critical products like gaskets and O-rings may be attacked by ozone produced within compressed air systems. Fuel lines are often made from reinforced rubber tubing and may also be susceptible to attack, especially within engine compartments where low levels of ozone are produced from electrical equipment.
Storing rubber products in close proximity to DC electric motors can accelerate the rate at which ozone cracking occurs. The commutator of the motor creates sparks which in turn produce ozone.
Kevin Stewart 05-10-2010 09:04 PM
i am not so much worried about cracking with ozone as i am with hardening the compound, Kevin
