-   -   Help! Can't remove hood crest (http://forums.pelicanparts.com/porsche-911-technical-forum/541682-help-cant-remove-hood-crest.html)
vulcan300 05-10-2010 01:50 PM
I'm currently stripping my 86 911 Targa down to repaint it and have run into trouble with the hood crest. I attempted to remove the nuts with an 8mm ratchet and they are just spinning. Is there anything special that I need to do to get the crest off?
chris.817 05-10-2010 01:52 PM
They should back out. If not, pry the nuts off and replace. They are very soft.
tomphot 05-10-2010 01:57 PM
I had to use some long nose pliers to get them off. Grabbed the nut and pulled while turning got them off.
vulcan300 05-10-2010 02:12 PM
Sweet. I'll try the long nose pliars and if that fails I'll try a bit of prying. Thanks for the advice!
Canada Kev 05-10-2010 08:10 PM
Try prying them a little bit while turning them. Often nuts will strip the first little bit, but when they bite by prying them a little bit, they screw right off.
JFairman 05-10-2010 08:18 PM
If nothing else works try a heat gun on the back side just case someone used a little hot glue to help keep it on.
Geronimo '74 05-10-2010 10:09 PM
if all else fails, break of the studs and replace the crest. (crests from an 86 are not that collectable)
A respray looks better with a new crest anyway.
newms 05-10-2010 11:36 PM
Don't pry the nuts off but gently pry the badge while backing off the nuts...the studs are not threaded and the nuts will just turn without a bit of pressure. The badge will bend so be careful.
