 XDI Tach Signal
		I've installed an elecromotive crankfire wasted spark ignition, works great.  However, when I tie my data acquisition system into the tach signal, the DA system will read a clean tach up to about 4000 RPM (above 3000 it jumps around, but will indicate a peak of about 4100 RMP).   The stock tach reads perfectly.   I'm wondering if anyone else has found issues with getting a clean tach signal to a secondary digital display.
| All times are GMT -8. The time now is 05:08 PM. |
