ART C.'s Avatar
Pitted Headlight Glass
ANY IDEAS ON POLISHING HEADLIGHT GLASS TO ADD LUMENS OF OUTPUT?
Art
1971 911e Yellow cooling shroud
1995 GPZ1100
Old 12-12-2001, 12:05 PM
Early_S_Man's Avatar
Art,
Since replacement lenses for all of the production 911 headlamp assemblies are still available at a reasonable price, why not just replace the pitted lens?
The VW part for the '49-'66 Beetle is made by Hella and identical to the lens used in '65-'67 911/912 assemblies. The H1, H4, and H5 lenses are readily available from aftermarket suppliers, including Pelican!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-12-2001, 12:57 PM
I agree. Replacements lens are fairly cheap and readily available.
But if you must, I have had good luck removing the pits on turn signal lenses by using a belt sander with very fine sandpaper and then using a rubbering compound to bring them back to life. The results have been as good as new. I don't know how it would work on glass, however.
Old 12-12-2001, 01:18 PM
Super Moderator
cstreit's Avatar
I would just replace them and then apply the inexpensive headlight protection film available anywhere. Kept mine looking new for 3 years now, and is barely visible.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-12-2001, 01:30 PM
