NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
Spring plate covers
This post is a two part question.
1. Do all spring plate retaining covers (over the torsion bar at rear) tend to rust between the rubber bushing and the cover? If so - is this something that we just rough up until we find base metal? I'm thinking not.
2. Assuming that this is not common - does somebody out there have a pair available at a reasonable price? Shipping to central WI.
The id's of my covers are a really nasty appearance, with the area where the cover can have water collect under the bushing has grown some thick rust with a glazed appearance (since the busing was working against it).
In addition to the question - I found a great way to remove the old vulcanized rubber bushings. We use a rubber lagging vendor at my workplace who volunteered to soak my spring plates in a solvent and dissove the bushings. I'll report back here with results in a day or two. I'm happy not to have to cut my fingers all up (tried removing these mechanically already, and it was no fun!)
Thanks.
Chris.
Old 05-12-2010, 02:39 PM
Ray_G's Avatar
I have a decent set of covers I think. I can check on them tomorrow for you. If you will PM me your email address i can send a picture of them to you.
76 911S Targa
An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage!
Old 05-12-2010, 02:41 PM
pete3799's Avatar
spring plate covers are available from our host.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSshk_pg14.htm
Pete
79 911SC RoW
Old 05-12-2010, 03:26 PM
